Amplifier Research FM 2000
The Amplifier Research FM 2000 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research FM 2000:
The frequency range of the Amplifier Research FM 2000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research FM 2000.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research FM 2000 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Amplifier Research FM 2000
- Google image search: Amplifier Research FM 2000
