Amplifier Research FP3000A
Jump to: navigation, search
The Amplifier Research FP3000A device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research FP3000A:
ScreenElementDescription.png Measure The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable.
ScreenElementDescription.png Max. Difference If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop.
The frequency range of the Amplifier Research FP3000A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research FP3000A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research FP3000A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
