Amplifier Research PM 2003 Channel 2
The Amplifier Research PM 2003 Channel 2 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research PM 2003 Channel 2:
The frequency range of the Amplifier Research PM 2003 Channel 2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research PM 2003 Channel 2.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research PM 2003 Channel 2 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Amplifier Research PM 2003 Channel 2
- Google image search: Amplifier Research PM 2003 Channel 2
