Amplifier Research TC3020A
The Amplifier Research TC3020A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research TC3020A:
The frequency range of the Amplifier Research TC3020A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research TC3020A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research TC3020A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Amplifier Research TC3020A
- Google image search: Amplifier Research TC3020A
