AnaPico APSIN 6000
The AnaPico APSIN 6000 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the AnaPico APSIN 6000:
The frequency range of the AnaPico APSIN 6000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the AnaPico APSIN 6000.
Be careful changing these setting as RadiMation® is no longer able to verify if the AnaPico APSIN 6000 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: AnaPico APSIN 6000
- Google image search: AnaPico APSIN 6000
