Anritsu 68255B
The Anritsu 68255B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Anritsu 68255B:
The frequency range of the Anritsu 68255B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Anritsu 68255B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Anritsu 68255B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Anritsu 68255B
- Google image search: Anritsu 68255B
