Anritsu 68277B
Jump to: navigation, search
The Anritsu 68277B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Anritsu 68277B:
The frequency range of the Anritsu 68277B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Anritsu 68277B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Anritsu 68277B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
