Anritsu MS2667C
Jump to: navigation, search
The Anritsu MS2667C device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Anritsu MS2667C:
The frequency range of the Anritsu MS2667C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Anritsu MS2667C.
Be careful changing these setting as RadiMation® is no longer able to verify if the Anritsu MS2667C is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
