Anritsu MS2713E 2000-1791-R
The Anritsu MS2713E 2000-1791-R device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Anritsu MS2713E 2000-1791-R:
The frequency range of the Anritsu MS2713E 2000-1791-R as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Anritsu MS2713E 2000-1791-R.
Be careful changing these setting as RadiMation® is no longer able to verify if the Anritsu MS2713E 2000-1791-R is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Anritsu MS2713E 2000-1791-R
- Google image search: Anritsu MS2713E 2000-1791-R
