Anritsu MS2760A-0044
Jump to: navigation, search
The Anritsu MS2760A-0044 device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Anritsu MS2760A-0044:
The frequency range of the Anritsu MS2760A-0044 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Anritsu MS2760A-0044.
Be careful changing these setting as RadiMation® is no longer able to verify if the Anritsu MS2760A-0044 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
