Bird 4421 Forward
The Bird 4421 Forward device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bird 4421 Forward:
The frequency range of the Bird 4421 Forward as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bird 4421 Forward.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bird 4421 Forward is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Bird 4421 Forward
- Google image search: Bird 4421 Forward
