Bird 4421 Reflected
Jump to: navigation, search
The Bird 4421 Reflected device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bird 4421 Reflected:
The frequency range of the Bird 4421 Reflected as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bird 4421 Reflected.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bird 4421 Reflected is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
