Bonn 0118-ABT
Jump to: navigation, search
The Bonn 0118-ABT device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn 0118-ABT:
The frequency range of the Bonn 0118-ABT as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn 0118-ABT.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn 0118-ABT is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
