Bonn BDC 0100-30
Jump to: navigation, search
The Bonn BDC 0100-30 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BDC 0100-30:
The frequency range of the Bonn BDC 0100-30 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn BDC 0100-30.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn BDC 0100-30 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
