Bonn BLMA 1060-200 Internal Coupler
Jump to: navigation, search
The Bonn BLMA 1060-200 Internal Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLMA 1060-200 Internal Coupler:
The frequency range of the Bonn BLMA 1060-200 Internal Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn BLMA 1060-200 Internal Coupler.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn BLMA 1060-200 Internal Coupler is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
