Bonn BLMA 1826-2M
The Bonn BLMA 1826-2M device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLMA 1826-2M:
The frequency range of the Bonn BLMA 1826-2M as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn BLMA 1826-2M.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn BLMA 1826-2M is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Bonn BLMA 1826-2M
- Google image search: Bonn BLMA 1826-2M
