Bonn BLWA 0210-5000
The Bonn BLWA 0210-5000 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bonn BLWA 0210-5000:
The frequency range of the Bonn BLWA 0210-5000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Bonn BLWA 0210-5000.
Be careful changing these setting as RadiMation® is no longer able to verify if the Bonn BLWA 0210-5000 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Bonn BLWA 0210-5000
- Google image search: Bonn BLWA 0210-5000
