Boonton 4220
Jump to: navigation, search
The Boonton 4220 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Boonton 4220:
The frequency range of the Boonton 4220 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Boonton 4220.
Be careful changing these setting as RadiMation® is no longer able to verify if the Boonton 4220 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
