Boonton 4230 Channel 1
Jump to: navigation, search
The Boonton 4230 Channel 1 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Boonton 4230 Channel 1:
The frequency range of the Boonton 4230 Channel 1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Boonton 4230 Channel 1.
Be careful changing these setting as RadiMation® is no longer able to verify if the Boonton 4230 Channel 1 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
Boonton 9241
The Boonton 9241 supports an emulation of the Boonton 4230 powermeter. If that emulation mode is used in the Boonton 9241, the RadiMation® device driver for the Boonton 4230 can be used to control the Boonton 9241. This does however require that the following settings in the setup menu of the Boonton 9241 are set:
  • Emulation: 4230
  • EOS LSTN: LF
  • EOS TALKER: LF
