Boonton 9200B Channel 1
The Boonton 9200B Channel 1 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Boonton 9200B Channel 1:
The frequency range of the Boonton 9200B Channel 1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Boonton 9200B Channel 1.
Be careful changing these setting as RadiMation® is no longer able to verify if the Boonton 9200B Channel 1 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Boonton 9200B Channel 1
- Google image search: Boonton 9200B Channel 1
