COM-POWER AB-900A
Jump to: navigation, search
The COM-POWER AB-900A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the COM-POWER AB-900A:
The frequency range of the COM-POWER AB-900A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the COM-POWER AB-900A.
Be careful changing these setting as RadiMation® is no longer able to verify if the COM-POWER AB-900A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
