COM-POWER CDN-T8SE
The COM-POWER CDN-T8SE device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the COM-POWER CDN-T8SE:
The frequency range of the COM-POWER CDN-T8SE as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the COM-POWER CDN-T8SE.
Be careful changing these setting as RadiMation® is no longer able to verify if the COM-POWER CDN-T8SE is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: COM-POWER CDN-T8SE
- Google image search: COM-POWER CDN-T8SE
