Ceyear technologies 1465A
The Ceyear technologies 1465A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ceyear technologies 1465A:
The frequency range of the Ceyear technologies 1465A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ceyear technologies 1465A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ceyear technologies 1465A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Ceyear technologies 1465A
- Google image search: Ceyear technologies 1465A
