Ceyear technologies 1465L-V
Jump to: navigation, search
The Ceyear technologies 1465L-V device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ceyear technologies 1465L-V:
The frequency range of the Ceyear technologies 1465L-V as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ceyear technologies 1465L-V.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ceyear technologies 1465L-V is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
