Ceyear technologies 87235F
Jump to: navigation, search
The Ceyear technologies 87235F device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ceyear technologies 87235F:
The frequency range of the Ceyear technologies 87235F as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ceyear technologies 87235F.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ceyear technologies 87235F is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
