Ceyear technologies 87235FA
Jump to: navigation, search
The Ceyear technologies 87235FA device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ceyear technologies 87235FA:
The frequency range of the Ceyear technologies 87235FA as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ceyear technologies 87235FA.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ceyear technologies 87235FA is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
