Chapter 19
Jump to: navigation, search
Appendices
Appendix A: RadiMation® Support Procedure
Definitions
Malfunctions are divided in nine categories and prioritized on their severity:
  • 1 - Incorrect Measurement: RadiMation® software produces incorrect measurement results.
  • 2 - Issue with Data Loss: RadiMation® software contains a problem that resulted in a situation that data is lost.
  • 3 - Crash/Issue - No Data Loss: RadiMation® is aborted during operation without any specific reason or another issue occurred. After a restart, no data is lost.
  • 9 - Required device driver: A device driver for a measurement instrument must be created.
  • 4 - Mandatory New Functionality: Functionality that is currently not implemented, but that is required to provide support for a new standard or measurement method.
  • 5 - Unexpected Functionality: All other cases of malfunction of RadiMation®, where the software functionality is responding differently than expected.
  • 6 - Cosmetic: RadiMation® software functions normal but the lay-out of the tables, graphs or screens are not represented in a proper way. For example when:
    • (Parts of) labels or information are not displayed.
    • (Parts of) labels or information are overwritten by other labels or other information.
    • The screen 'flashes' while writing graphs or other information.
    • The manual contains an error or unclear description.
  • 7 - Questions: End-user has a question about the operation of the RadiMation® software.
  • 8 - Wish: RadiMation® software is missing specific functionality which should be evaluated for possible implementation in the future. In this category, there is not a real problem however the end-user requests RadiMation® to function in a different way or requests additional functionality. This can even mean that the actual situation is unworkable for the end-user. This case encompasses situations where certain functionality or part of tests is not supported.
Error report procedure
The goal of the 'Error report procedure' is to support customers as quick and effective as possible.
Reporting a problem when an error is shown
  1. On the RadiMation® Error Window, press the Report button.
  2. The Error Report window will be shown.
  3. Specify your own contact details, so we know how to contact you for a solution. As seen in the screenshot, you also must check the I agree that my provided data is used to improve the products and services of Raditeq checkbox.
  4. Ensure that all the fields do contain the correct information. If not all fields are filled you can not send or save the file. When information is missing, a red circle with a cross is displayed. If you hover over it with your mouse it will inform you what is missing in the form.
  5. Once the report information is filled in the buttons change colour, the report can now be send to the RadiMation® support team in 2 ways:
    • Send the report automatically using the Send button. A message will be shown that the error report is transmitted. You also will receive almost directly an e-mail from our ticket database with the ticket number that has been created for your error report.
    • Save the report with the Save button, and send the file over email to radimation-support@raditeq.com
Manually reporting an issue
   Menu.png Help
      Menu.png Report .
Reporting a RadiLog communication file only
  1. Open the RadiMation® logging tool (RadiLog) from the View menu in RadiMation®
  2. While the RadiLog tool is opened, reproduce the error.
  3. When the error has been logged, save the log file, by selecting 'File' and 'Save As...' from the menu.
  4. Send the .RadiLog file (zipped) to the RadiMation® support e-mail address radimation-support@raditeq.com
Sending larger files
Appendix B: Maintenance
The service of solving 'bugs' in the software is covered by the maintenance contract. Depending on the situation it might be necessary for an engineer from Raditeq to supply on-site support. These costs are covered as well, excluding travel and lodging. The service contract entitles the customer to all new push releases for the respective module(s).
Functionality improvements and/or changes to the respective software module(s) that are desired by the customer (and are assessed by Raditeq as functional and commonly applicable), will be implemented in a future release of the software. It is important to keep in mind that improvements and/or changes for one customer should not lead to disadvantages for other customers.
The RadiMation® Support/Upgrade contract is mandatory and should be ordered with each RadiMation® order.
  • The minimum duration of this contract is 2 years.
  • The first year is free of charge, each subsequent year costs 10% of the software order value.
  • the starting date of the support/upgrade contract is the original delivery and/or installation date.
  • If a customer does not accept a support/upgrade contact, Raditeq will not provide any software support/upgrade service.
Releases
Releases are divided in major and minor releases, indicated by a release number in the xxxx.yy.zz format. In this format, 'xxxx.yy' indicates the major release version. Where the 'xxxx' specifies in which year the software has been released. The '.yy' indicates if it is the first (.1) or second (.2) major release. The '.zz' specifies the minor release version.
RadiMation® software releases can be downloaded from our website at: http://download.radimation.com/ .
The changes that are included in each version is available in the release notes of each version, that is available on or [RadiWiki website ( http://wiki.radimation.com )].
Major release
A major release consists of any and all new functionalities and bug fixes since the previous minor release. As such the major release is a base line release.
Minor release
A minor release is provided on top of the major release, to provide fixes for problems that has been found in the major releases. No new functionality will be added in these minor releases.
Release Planning
There will be two major releases of RadiMation® each year. The planning of these two major releases is:
  • 1st major: first week of April.
  • 2nd major: first week of October.
