Chase CBL 6111B
Jump to: navigation, search
The Chase CBL 6111B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Chase CBL 6111B:
The frequency range of the Chase CBL 6111B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Chase CBL 6111B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Chase CBL 6111B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
