Configurable Antenna Tower
Jump to: navigation, search
Communication
Identification
Configurable Antenna Tower commands
Initialisation and Check
ScreenElementDescription.png Reset The reset code that needs to be send to device. When left blank, no command will be send.
ScreenElementDescription.png Init The command that is send to initialize the configured device. When left blank no command will be send.
ScreenElementDescription.png Get Id The command that is send to retrieve the ID of the device. This is used to check if the device is connected. A commonly used SCPI command is: *IDN?. When left blank, no command will be send.
ScreenElementDescription.png Returned ID The identifier is used to check if the correct device driver is selected and the device is connected. Leaving this blank, will skip the device check.
ScreenElementDescription.png Deinit Specifies the command that is send when the device is no longer controlled. This can for example be used to put the measurement device is an intrinsic safe state. Leaving this blank, will keep the device in its last state after controlling it.
ScreenElementDescription.png Wait for Completion after sending command The checkmark can be enabled so RadiMation® will wait for all the commands to complete, before it continues. This is done by sending SCPI command *OPC? to the device.
Antenna Tower
ScreenElementDescription.png Stop Movement The command that is send to stop the antenna tower. When left blank, no command will be send.
ScreenElementDescription.png Current Height The command that is send to request the current height. When left blank no command will be send.
ScreenElementDescription.png Current Height Format A regular expression to parse the response from the Current Height request. The received value will be interpreted as being the the unit in Meter, Centimeter or Millimeter, as selected by the dropdownbox.
ScreenElementDescription.png Go to Height The command that is send to move the antenna tower to a certain height. The command must include a keyword, __meter__, __centimeter__ or __millimeter__ which will be replaced with the corresponding height for the antenna tower. When left blank, no command will be sent.
ScreenElementDescription.png Position stopped The command that is send to request the status if the antenna tower is moving. When left blank, no command will be send.
ScreenElementDescription.png Position stopped format A regular expression which will be matched against the response of the Position stopped command. When the result is matching with the response, the tower is stopped.
ScreenElementDescription.png Current Polarization The command to request the current polarisation. It is mandatory to also supply the format of the polarization in the next fields. When left blank, no command will be sent.
ScreenElementDescription.png Horizontal Polarization format A regular expression which will be matched against the response of the Current Polarization command. When the result is matching the driver reports Horizontal back to RadiMation.
ScreenElementDescription.png Vertical Polarization format A regular expression which will be matched against the response of the Current Polarization command. When the result is matching the driver reports Vertical back to RadiMation.
ScreenElementDescription.png Hor. Polarization The command that is send to change the polarization to horizontal. When left blank, no command will be send.
ScreenElementDescription.png Vert. Polarization The command that is send to change the polarization to vertical. When left blank, no command will be send.
ScreenElementDescription.png Pol Hor. stopped The command that is send after the command Hor. Polarization is sent, with a delay of Waiting time between the two commands. When left blank, no command will be send.
ScreenElementDescription.png Pol Vert. stopped The command that is send after the command Vert. Polarization is sent, with a delay of Waiting time between the two commands. When left blank, no command will be send.
ScreenElementDescription.png Waiting time The wait time, specified in milli seconds, between the Polarization command and Polarization stopped commands.
Antenna Tower Advanced
ScreenElementDescription.png Ignore height change When checked, no height related commands and changes will be send to the antenna tower. This can for example be checked if the the antenna is mounted on a fixed height tripod.
ScreenElementDescription.png Ignore polarisation change When checked, no polarisation related commands and changes will be send to the Antenna Tower. This can for example be checked if the antenna tower does not have a automatic polariser.
ScreenElementDescription.png Move antenna before measurement When checked, the antenna will be moved to the Start position before the actual test is started.
ScreenElementDescription.png Start position The height, specified in centimeters, to which the antenna is moved, before the actual test is started.
ScreenElementDescription.png Move antenna after measurement When checked, the antenna will be moved to the End position after the test has finished.
ScreenElementDescription.png End position The height, specified in centimeters, to which the antenna is moved, after the test has finished.
ScreenElementDescription.png Wait time The time, specified in seconds, to wait after a command is issued to change the polarisation. This can for example be used to include an additional delay to ensure that the antenna polariser has reached the final location before the actual test continues.
