Configurable Calibration Jig
Jump to: navigation, search
The following tabs are available in the advanced configuration of the Configurable Calibration Jig:
The frequency range of the Configurable Calibration Jig as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Configurable Calibration Jig.
Be careful changing these setting as RadiMation® is no longer able to verify if the Configurable Calibration Jig is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Start Frequency The lowest usable frequency of the device.
ScreenElementDescription.png Stop Frequency The highest usable frequency of the device.
ScreenElementDescription.png Resistance The impedance of the injection system itself, for which the calibration jig is used to calibrate it.
