Configurable Current Sensor
Jump to: navigation, search
The Configurable Current Sensor device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Configurable Current Sensor:
The frequency range of the Configurable Current Sensor as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Configurable Current Sensor.
Be careful changing these setting as RadiMation® is no longer able to verify if the Configurable Current Sensor is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
