Configurable LISN
Jump to: navigation, search
The following tabs are available in the advanced configuration of the Configurable LISN:
The frequency range of the Configurable LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Configurable LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the Configurable LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Reset The reset command that needs to be send to device. When left blank, no command will be send.
ScreenElementDescription.png Init The command that is send to initialize the configured device. When left blank no command will be send.
ScreenElementDescription.png Get ID The command that is send to retrieve the identity of the device. This is used to check if the device is connected. A commonly used SCPI command is: *IDN?. When left blank, no command will be send, and the device check is skipped.
ScreenElementDescription.png Returned ID A string that is used to check if the correct device driver is selected and the device is connected. The device check consists of a few steps. First the Get ID command is transmitted to the device, and the response from the device is then received. The received response is then searched for the string specified at Returned ID, and if the string is found it is confirmed that the correct device is connected. The string specified can also be a Regular expression, which is then used to find a match in the response from the device. Leaving this blank, will skip the device check, and it is silently assumed (but not checked) that the correct device is connected.
ScreenElementDescription.png Deinit Specifies the command that is send when the device is no longer controlled. This can for example be used to put the measurement device is an intrinsic safe state. Leaving this blank, will keep the device in its last state after controlling it.
ScreenElementDescription.png Wait for Completion after sending command The checkmark can be enabled so RadiMation® will wait for all the commands to complete, before it continues. This is done by sending SCPI command *OPC? to the device.
ScreenElementDescription.png Neutral The command that should be transmitted when the 'Neutral' line of the LISN should be selected. If no command is specified, nothing will be transmitted.
ScreenElementDescription.png Line 1 The command that should be transmitted when the 'Line 1' line of the LISN should be selected. If no command is specified, nothing will be transmitted.
ScreenElementDescription.png Line 2 The command that should be transmitted when the 'Line 2' line of the LISN should be selected. If no command is specified, nothing will be transmitted.
ScreenElementDescription.png Line 3 The command that should be transmitted when the 'Line 3' line of the LISN should be selected. If no command is specified, nothing will be transmitted.
ScreenElementDescription.png Ok Closes the dialog, where all the changed settings are stored.
ScreenElementDescription.png Cancel Closes the dialog, where all the changed settings are discarded.
ScreenElementDescription.png Communication Opens an additional dialog which allows to set the correct communication medium to communicate with the device, including any relevant settings.
