D.A.R.E!! Development RadiMate Forward Power
Jump to: navigation, search
The D.A.R.E!! Development RadiMate Forward Power device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the D.A.R.E!! Development RadiMate Forward Power:
The frequency range of the D.A.R.E!! Development RadiMate Forward Power as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the D.A.R.E!! Development RadiMate Forward Power.
Be careful changing these setting as RadiMation® is no longer able to verify if the D.A.R.E!! Development RadiMate Forward Power is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
