DARE!! Development RadiMate Reflected Power
The DARE!! Development RadiMate Reflected Power device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Development RadiMate Reflected Power:
The frequency range of the DARE!! Development RadiMate Reflected Power as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Development RadiMate Reflected Power.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Development RadiMate Reflected Power is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: DARE!! Development RadiMate Reflected Power
- Google image search: DARE!! Development RadiMate Reflected Power
