DARE!! Development RadiSense II X-Axis
The DARE!! Development RadiSense II X-Axis device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Development RadiSense II X-Axis:
The frequency range of the DARE!! Development RadiSense II X-Axis as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Development RadiSense II X-Axis.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Development RadiSense II X-Axis is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: DARE!! Development RadiSense II X-Axis
- Google image search: DARE!! Development RadiSense II X-Axis
