DARE!! Development RadiSense IV
The DARE!! Development RadiSense IV device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Development RadiSense IV:
The frequency range of the DARE!! Development RadiSense IV as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Development RadiSense IV.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Development RadiSense IV is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
There are several methods in which the DARE!! Development RadiSense IV can be connected to the PC. The DARE!! Development RadiSense IV can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the DARE!! Development RadiSense IV is connected.
When the DARE!! Development RadiSense IV is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
Directly to PC | Specifies that the DARE!! Development RadiSense IV is connected directly to the PC, without the use of a RadiCentre. |
RadiCentre 1 | Specifies that the DARE!! Development RadiSense IV is connected to a plugincard that is fitted in a RadiCentre 1. |
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the DARE!! Development RadiSense IV itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the DARE!! Development RadiSense IV is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the DARE!! Development RadiSense IV:
- RadiCentre tab
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The Software update tab can be used to update the software of the DARE!! Development RadiSense IV.
The RadiSense tab can be used to configure the specific settings of the DARE!! Development RadiSense IV.
Direction | If the field strength of a specific single axis or an isotropic value should be measured. |
Band selection | Allows if the Low frequency band, High frequency band, or both frequency bands should be used for the electrical field strength measurement. |
RadiSense Firmware Version | Allows to select the firmware version that is present in the RadiSense probe. This information is used to used version specific commands to control the RadiSense. |
Filter Setting | The filter that should be used during the measurements. |
Automatically turn laser on | If this option is checked, the driver will automatically activate the laser when the device is being used. |
