DARE!! Development RadiSense IV (RadiCentre)
Jump to: navigation, search
The DARE!! Development RadiSense IV (RadiCentre) device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Development RadiSense IV (RadiCentre):
ScreenElementDescription.png Measure The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable.
ScreenElementDescription.png Max. Difference If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop.
The frequency range of the DARE!! Development RadiSense IV (RadiCentre) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Development RadiSense IV (RadiCentre).
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Development RadiSense IV (RadiCentre) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
There are several methods in which the DARE!! Development RadiSense IV (RadiCentre) can be connected to the PC. The DARE!! Development RadiSense IV (RadiCentre) can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the DARE!! Development RadiSense IV (RadiCentre) is connected.
When the DARE!! Development RadiSense IV (RadiCentre) is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
ScreenElementDescription.png Directly to PC Specifies that the DARE!! Development RadiSense IV (RadiCentre) is connected directly to the PC, without the use of a RadiCentre.
ScreenElementDescription.png RadiCentre 1 Specifies that the DARE!! Development RadiSense IV (RadiCentre) is connected to a plugincard that is fitted in a RadiCentre 1.
ScreenElementDescription.png RadiCentre multi-slot Specifies that the DARE!! Development RadiSense IV (RadiCentre) is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected.
ScreenElementDescription.png RadiCentre multi-slot Ultra Specifies that the DARE!! Development RadiSense IV (RadiCentre) is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled.
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the DARE!! Development RadiSense IV (RadiCentre) itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the DARE!! Development RadiSense IV (RadiCentre) is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the DARE!! Development RadiSense IV (RadiCentre):
  • RadiCentre tab
  • Communication tab
    • Communication Stream: VISA
    • LAN: 192.168.178.95
The Software update tab can be used to update the software of the DARE!! Development RadiSense IV (RadiCentre).
Warning: The software update can take a few minutes. During the actual software update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the DARE!! Development RadiSense IV (RadiCentre) and the PC, while the software update is being performed.
The RadiSense tab can be used to configure the specific settings of the DARE!! Development RadiSense IV (RadiCentre).
ScreenElementDescription.png Direction If the field strength of a specific single axis or an isotropic value should be measured.
ScreenElementDescription.png Band selection Allows if the Low frequency band, High frequency band, or both frequency bands should be used for the electrical field strength measurement.
ScreenElementDescription.png RadiSense Firmware Version Allows to select the firmware version that is present in the RadiSense probe. This information is used to used version specific commands to control the RadiSense.
ScreenElementDescription.png Filter Setting The filter that should be used during the measurements.
ScreenElementDescription.png Automatically turn laser on If this option is checked, the driver will automatically activate the laser when the device is being used.
