DARE!! Instruments RGN2006B
Jump to: navigation, search
The DARE!! Instruments RGN2006B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RGN2006B:
The frequency range of the DARE!! Instruments RGN2006B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Instruments RGN2006B.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Instruments RGN2006B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
