DARE!! Instruments RPA0810A-010
The DARE!! Instruments RPA0810A-010 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RPA0810A-010:
The frequency range of the DARE!! Instruments RPA0810A-010 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Instruments RPA0810A-010.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Instruments RPA0810A-010 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
There are several methods in which the DARE!! Instruments RPA0810A-010 can be connected to the PC. The DARE!! Instruments RPA0810A-010 can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the DARE!! Instruments RPA0810A-010 is connected.
When the DARE!! Instruments RPA0810A-010 is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
Directly to PC | Specifies that the DARE!! Instruments RPA0810A-010 is connected directly to the PC, without the use of a RadiCentre. |
RadiCentre 1 | Specifies that the DARE!! Instruments RPA0810A-010 is connected to a plugincard that is fitted in a RadiCentre 1. |
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the DARE!! Instruments RPA0810A-010 itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the DARE!! Instruments RPA0810A-010 is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the DARE!! Instruments RPA0810A-010:
- RadiCentre tab
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The output channel of amplifiers supporting multiple output channels can be configured
Channel | Select the channel to be used by the DARE!! Instruments RPA0810A-010. |
The Software update tab can be used to update the software of the DARE!! Instruments RPA0810A-010.
