DARE!! Instruments RadiLink
Jump to: navigation, search
The DARE!! Instruments RadiLink device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RadiLink:
The frequency range of the DARE!! Instruments RadiLink as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Instruments RadiLink.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Instruments RadiLink is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
