DeviceDriverGenericConfigurationAntenna
Jump to: navigation, search
Note: This page is used to show the configuration that is generic for all antenna device drivers. This page will automatically be embedded on all antenna device driver pages.
The following tabs are available in the advanced configuration of the DeviceDriverGenericConfigurationAntenna:
The frequency range of the DeviceDriverGenericConfigurationAntenna as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DeviceDriverGenericConfigurationAntenna.
Be careful changing these setting as RadiMation® is no longer able to verify if the DeviceDriverGenericConfigurationAntenna is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
