DeviceDriverGenericConfigurationLISN
The following tabs are available in the advanced configuration of the DeviceDriverGenericConfigurationLISN:
The frequency range of the DeviceDriverGenericConfigurationLISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DeviceDriverGenericConfigurationLISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the DeviceDriverGenericConfigurationLISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
