EATON 94607-1
Jump to: navigation, search
The EATON 94607-1 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EATON 94607-1:
The frequency range of the EATON 94607-1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EATON 94607-1.
Be careful changing these setting as RadiMation® is no longer able to verify if the EATON 94607-1 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
