EMCO 3101
The EMCO 3101 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 3101:
The frequency range of the EMCO 3101 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EMCO 3101.
Be careful changing these setting as RadiMation® is no longer able to verify if the EMCO 3101 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
