EMCO 3146DP
The EMCO 3146DP device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 3146DP:
The frequency range of the EMCO 3146DP as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EMCO 3146DP.
Be careful changing these setting as RadiMation® is no longer able to verify if the EMCO 3146DP is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: EMCO 3146DP
- Google image search: EMCO 3146DP
