EMCO 7110 Probe 2
The EMCO 7110 Probe 2 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 7110 Probe 2:
The frequency range of the EMCO 7110 Probe 2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EMCO 7110 Probe 2.
Be careful changing these setting as RadiMation® is no longer able to verify if the EMCO 7110 Probe 2 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: EMCO 7110 Probe 2
- Google image search: EMCO 7110 Probe 2
