EMCO 7123
The EMCO 7123 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 7123:
The frequency range of the EMCO 7123 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EMCO 7123.
Be careful changing these setting as RadiMation® is no longer able to verify if the EMCO 7123 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
