EMCO 93110B
The EMCO 93110B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 93110B:
The frequency range of the EMCO 93110B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EMCO 93110B.
Be careful changing these setting as RadiMation® is no longer able to verify if the EMCO 93110B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: EMCO 93110B
- Google image search: EMCO 93110B
