EMC Shop DC1G-100
The EMC Shop DC1G-100 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMC Shop DC1G-100:
The frequency range of the EMC Shop DC1G-100 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EMC Shop DC1G-100.
Be careful changing these setting as RadiMation® is no longer able to verify if the EMC Shop DC1G-100 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: EMC Shop DC1G-100
- Google image search: EMC Shop DC1G-100
