ENI 510LA
Jump to: navigation, search
The ENI 510LA device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ENI 510LA:
The frequency range of the ENI 510LA as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the ENI 510LA.
Be careful changing these setting as RadiMation® is no longer able to verify if the ENI 510LA is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
